Alternator Whine with aftermarket Radio
i installed a Pioneer AVH-p6800dvd few months down the road i started getting a whine in my interior speakers after i tried installing a tv tunner. So i removed it.
I tried everything relocating the Grounds
Ground loop isolators
i even called a stereo shop and they told me 3 out of 5 GM will have that problem.
I also searched on the web and Pioneer is known to have faulty Ground wire from radios
I have read that people ran a Ground wire straight from the Battery (is this safe)
Then i read that chasis of the car has Welds which will produce a Ground loop.
i dont know what to do ...
First i thought it was my Metra Harness so i sent back to factory and they sent me a new one and i still have that problem
ANYBODY HAVE ANY ADVICE FOR ME IM ABOUT TO SMASH MY RADIO!!!!!!
My next step is to get my friends Pioneer radio and plug it into my car if i still have The whine then i know its my car if i dont then iknow its the radio.............
RE: Alternator Whine with aftermarket Radio
A ground wire straight from the Battery is okay, but now you have bypassed your iginiton which could cause a slow drain. You might want to look at a basic ground filter and not an isolator/Loop. Also you could try a seperate ground wire straight off of the radio/steel case to the body but you have to make sure you have good contact, you might have to clean a spot off with sand paper to get bare metal contact then cover the screw/bolt with silicone to prevent corrosion. Another simple check is make sure your Battery terminals are clean and your connections are secure on the alternator. Sometimes the most simplest mistake causes the problem.
http://buyreliant.com/caudio/noise.htm
Some Help maybe: http://www.crutchfieldadvisor.com/IS...de.html?page=2
I SOLVED IT!!!!
i just so happens i blew the mircro fuse in my pioneer radio so i had to ground the outer coating of the rca to ground. People claim that is a temporary fix.
I have the moonsoon sound system with the metra gmos-04
DirtyH3
07-22-2009 09:41 PM
dmac
01-26-2009 12:23 AM
