[ View Full Version Of This Page ]
305 or 325?
All Forums » Hummer H3 » 305 or 325?
Stealthhawaii
3/16/2006 5:16:58 AM
I'm gettin ready to get new tires, any suggestions on sizes 305/70-16 or 325/70-16?
Comments and Advice welcomed!
Stealthhawaii
Shadow Green, adventure package.
dilo2001gt
3/16/2006 7:56:15 AM
the bigger the better
nascar 17
3/16/2006 10:28:12 PM
i was looking to get the 305 70 16 or the 315 75 16 whats the diffrence with the 325 70 16 ?
Dennis
3/16/2006 10:38:49 PM
quote:
ORIGINAL: nascar 17
They're wider...
The 315/75R16 are 34.6 inches in diameter
The 325/70R16 are 33.9 inches in diameter..but wider
Keep in mind the first number is the width and the second number is the percentage of width in side wall height
nascar 17
3/16/2006 10:42:23 PM
If the 325 is wider then the 315 and some one on here said the 315 hits a little bit then i would think the 325 being wider would really hit i dont know i guess it would ????thats why i dont know to go with the 315 75 16 or the 305 70 16. i want 1 inch taller and 1 inch wider then the 285.
Dennis
3/16/2006 10:59:02 PM
quote:
ORIGINAL: nascar 17
The first number is the width in Millimeters from side wall bulge to side wall bulge across the tire.
285 = 11.22 inches
295 = 11.61 inches
305 = 12.00 inches
315 = 12.40 inches
325 = 12.79 inches
I would turn my wheels to full lock and then measure the distance of your tires now, to the nearest inner wheel well area that could rub on the tire..Both tires as they sit in this full cranked position..This should give you an idea of how much wider you can afford to go before something rubs..(use list of dimensions above for comparison)
nascar 17
3/16/2006 11:18:18 PM
So what do you think would be the best look with the space i have now form leveling mine out ?
Dennis
3/16/2006 11:30:05 PM
quote:
ORIGINAL: nascar 17
To be safe with clearence..LT295/75R16 BFGs All-Terrain T/A KO..That's 33.4 inches in diameter..This is what I'm gonna get anyway!
Stealthhawaii
3/18/2006 6:47:38 AM
Anyone know how 315/75-16 fit with the stock wheel?
skeeet
3/19/2006 12:12:18 AM
It will fit but it is NOT recommended by any tire manufacturer. I believe the mininum rim width should be 8".
Related Threads
Return to the Hummer Forums home page - Archive Home
